18 years agoPCI Express - chaining DMA - newbie Q
hello, i'm stuck (rather newbie) and would like to ask if i'm taking the right approach. i used the pci express compiler user guide 8.0 using the megawizard to create a pci express soft ...
17 years agoThank you for reporting your success here, it helps me get the driver accepted in mainstream Linux.
There are issues with the legacy-interrupt mechanism in the 8.x series of the chaining DMA example. I may have some emails and notes to report back here, but maybe others can help, as I did not test nor use non-MSI. The driver should work with legacy interrupts once the FPGA logic works correctly.
