18 years agoPCI Express - chaining DMA - newbie Q
hello, i'm stuck (rather newbie) and would like to ask if i'm taking the right approach. i used the pci express compiler user guide 8.0 using the megawizard to create a pci express soft ...
17 years agoHello,
Thanks a lot to *likewise* for writing and publishing the linux driver. It gave me a very good point to start. And actually it worked great for me. I am using an Arria GX Development Kit. Now i have to port the driver to another realtime operating system. Unfortunately i don't get MSI (Message Signaled Interrupts) to run with that other operating system. What would i have to change on the driver to use legacy interrupts instead? Is it possible at all, or do i have to change the FPGA image? I assume i have to write a different value to w0... but what exactly? --- Quote Start --- ape->table_virt->desc[n].w0 |= cpu_to_le32(1UL << 16)/*local MSI*/; --- Quote End --- Unfortunately my own knowlede about FPGA is very limited. Where can i get that information? I currently just use the standard image that came installed with the Development Kit. Thanks a lot!
