one of the 'Timing Optimization Advisor' recommendations for my design is to define a list of clocks as Global Clock in the Assignment editor. how do i do that?
usually, if the name was correct after doing the above suggestion. You will find a green tick there in the assignment editor.
- OLevy16 years ago
thanks for the answers but what i get in the report are names that can not be found by the Node Finder.
for example (one of the clocks i get in the report):
'crm_inst|freeclk_pll_inst|pll_inclk50mhz_normal_inst|altera_pll_i|general[0].gpll~FRACTIONAL_PLL|vcoph[0]'
i have found 'crm:crm_inst|pll_inclk50MHz_normal:freeclk_pll_inst|outclk_0' in the Node Finder. configured it as 'Global Signal' in the 'Assignment Name' column and 'Global Clock' in the 'Value' column.
and after the compilation i still get the same line in the report (Node Name - crm_inst|freeclk_pll_inst|pll_inclk50mhz_normal_inst|altera_pll_i|general[0].gpll~FRACTIONAL_PLL|vcoph[0], Global Resource Used - No)
