12 years agoOn-chip FIFO in Qsys - How to read/write from/to an SCFIFO?
Hello everyone,
I am implementing an MM to MM FIFO in single-clock mode under Qsys. Now, I try to understand how to read and write from it. The API gives the following code for the read and write functions : Prototype: int altera_avalon_fifo_read_fifo(alt_u32 read_address, alt_u32 ctrl_address) Parameters: read_address—the base address of the FIFO read slave ctrl_address—the base address of the FIFO control slave Prototype: int altera_avalon_write_fifo(alt_u32 write_address, alt_u32 ctrl_address, alt_u32 data) Parameters: write_address—the base address of the FIFO write slave ctrl_address—the base address of the FIFO control slave data—the value to write to address offset 0 for Avalon-MM to Avalon-ST transfers, the value to write to the single address available for Avalon-MM to Avalon-MM transfers. See the Avalon Interface Specifications for the data ordering. I implemented a FIFO without any status port (the datasheet says it is optional). But my question is : how to use the read and write functions if I don't have such ports? It seems like the needed "ctrl_address" refers to this type of ports. I could add such a csr port, but on an SCFIFO, it is allowed to do so only on the input side (only the in_csr port is allowed). ...So it seems like I can at best only write and not read anything. Does someone have a clear explanation for me ? Thanks a lot, ArkadyNo RepliesBe the first to reply
