not able to generate sdo for arria 10 soc for post-synthesis timing simulation
Can you attached your
1) *.sdc files
2)top_level.v files
3) Timing report.rprt files
for us to have a look? Let's review the *.sdc before we proceed further.
- VenkateshSathar6 years ago
yeah. now i could able to see the failing paths in setup time by changing the default tcl commands which generates for only 10 paths to some 100000 paths where as in histogram failures are that many. IN that some are related to our application and seen it and changed the codes and in hardware it worked for 160MHz clock and 100MHz also. Now the same code I am changing the clock to 200MHz and now some other timing path fails and even i give latency etc also not getting corrected for Fast 900mv 100C model. Can you suggest something for how to proceed for this really high frequency clock where as slack is not reducing.
