JWall40
6 years agoNo output from FFT IP
I am trying to perform a FFT on a single 1024 sample frame, using streaming architecture. However, I cannot get source_valid to go high or any output. Here's my signal tap 4k samples Start of...
omerc
4 years agoDear @CheePin_C_Intel ,
I did not fully get the implications of using the block floating point and fixed point and the difference of the consequences of using them. I get a working and erroneous implementation by using the fixed point variable streaming and block floating point streaming configurations of the FFT IP. the problem is explained in the following thread:
Do you have any idea why would block floating point could generate an missing_sop error in such a design where fixed point do not?
I would much appreciate if you can help me with this issue.
Best Regards
