Nios development board excalibur kit Altera
- KellyJialin_Goh
Greetings and welcome to Intel's forum.
Could you kindly translate your question to English as it will be difficult for me to understand your question properly.
Thank you.
Kelly
- KellyJialin_Goh
You may find the SDK information on NIOS II command shell with this link here: https://www.intel.com/content/www/us/en/docs/programmable/683282/current/starting-the-nios-ii-command-shell.html
Thank you.
Kelly
- Giovanni3
I need to nios sdk shell and not nios II. Is it available nios sdk shell?
- KellyJialin_Goh
You will need follow this link to generate BSP: https://www.intel.com/content/www/us/en/docs/programmable/683689/current/application-12184.html
1)Click Generate BSP. Make sure the BSP generation is successful.
2)Close the BSP Editor.
I will attach a picture for your reference on the button to Generate BSP.
Thank you.
Kelly
- KellyJialin_Goh
Any updates from your side? Do you need any further clarification from my end?
Thank you.
Kelly
- Giovanni3
I didn't solve, i need the quartus version which contains Nios SDK shell
- KellyJialin_Goh
Thank you.
Kelly
- KellyJialin_Goh
May I know the Quartus version you are using?
The devkit you are using is actually quite old and will have to check if it is still supported from our end.
Hope to hear from you soon.
Thank you.
Kelly
- KellyJialin_Goh
Thank you.
Kelly
- KellyJialin_Goh
Any updates from your side? Do you need any further clarification from my end regarding your issue?
Thank you.
Kelly
- KellyJialin_Goh
Thank you.
Kelly Jialin, GOH
