13 years agoNew IP development
Hello, I am interested in developing some instructions which can do the bignum operations (like adding two operands of 1024 bit) and hence by plan to implement a simple Full Adder like this: ...
13 years agoThank you for the explanation, Ted! Glad that I met you here who knows how to explain clearly, for a beginner in Quartus II like me.
So I am just confirming the tentative design to make sure we on the same page. Please see the attached diagram which shows the entire design for a typical RSA application. The NIOS II core uses the RSA IP core to implement the RSA in hardware. The RSA IP core talks with the BIGDIGITS IP core to get the desired bignum functionality. The control path will be from NIOS II -> RSA -> BIGDIGITS. And as you pointed out, the BIGDIGITS will have a custom instruction interface for the control signal to increase the speed. The functionality of that custom instruction is, output = input. It just passes along the address (for both the operands) and the 'opcode' to perform for the BIGDIGITS. The data path will be from the on chip memory to the BIGDIGITS IP core. Hope the above design is an okay one for me to start implementation in Qsys (I need to learn that as well, huh ! I had so far been an SOPC guy.) Thank You, Akhil
