Yuexia's avatar
Yuexia
2 years ago
need a high-temperature FPGA chip which can work in the150 degree environment
Our product needs to work in the150 degree environment. In the early stage of the project, chip selection requires a high-temperature FPGA product series with a main frequency of 40MHz or above
  • NazrulNaim_Intel's avatar
    NazrulNaim_Intel
    Good day
    Sorry for the delay as I was out of office for a long period. Thank you for reaching out. I'm Nazrul Naim looking into your issue and allow me some time to look into your issue. I shall come back to you with findings.
    Thank you for your patience.
    Nazrul Naim
  • givememessage's avatar
    givememessage
    1. Stratix IV GX FPGA: The high-temperature version of this FPGA is often referred to as "Stratix IV GX FPGA - HT," where "HT" stands for "High Temperature." They provide high performance over the operating temperature range and have main frequencies above 40MHz.
      Arria II GX FPGA: Similarly, there are versions of the Arria II GX FPGA that are suitable for high-temperature environments and can operate in environments up to 150 degrees. You'll want to look for a specific model to make sure it meets your performance requirements.
      Stratix III FPGA: This is also another alternative. Some models of Stratix III FPGA are also suitable for high temperature environments and have higher clock speed and stability.
      When selecting, be sure to review the spec sheet for your specific model to ensure it meets your performance and temperature requirements
    Email:[email protected]
    NazrulNaim_Intel
    It has been a while since you posted an update to this SR. Do you have any updates for me? If you do not have further inquiries, I would like to put this SR in close-pending status.
    You may post an update anytime during the 14-day close-pending period if you have any further questions about this request.
    Thank You.
    Nazrul Naim
    NazrulNaim_Intel
    Nazrul Naim
