Native Phy Receiver not aligning properly
- 7 years ago
From the simulation, seems like the PCS-core width is 32 bits which I believe you have enable byte SERDES in your transceiver. For your information, if you have byte SERDES enabled, after achieving the word alignment, you would need to perform the byte ordering to get the correct data. For example, from the simulation, seems like the MSByte and LSByte order is swapped.
Just would like to check with you which device are you using? For V series devices, they have the byte ordering block supported.
Thank you.
Thank you.
