Длаза
6 years agomy PLL does not set "pll_locked" to 1 when I lower "pll_powerdown" to 0. The flag "PLL Auto Reset" is set in the IP core
a_x_h_75
Contributor
6 years agoWhat are you connecting pll_powerdown to? Are you using it with a Transceiver and is it connected to that? Is it connected to the correct reset controller?
The user guide states it "needs to be connected to a dynamically controlled signal". Don't expect it to work if you're driving it directly.
Cheers,
Alex
