Mathiazhagan's avatar
Mathiazhagan
4 years ago
Multiply and Accumulate Intel IP Core
Hi All,
Am using cyclone V E Version development board, am developing a project with the help of intel IP Cores, I could not find a IP for multiply and accumulate, after searching in google i came to know that cyclone V does not have a IP named Multiply and accumulate, Instead of it can use Multiply and adder so anyone please help me out how to realize the function (D-A)*B using the ipcore available,
Thanks in Advance
  • Mathiazhagan's avatar
    Mathiazhagan
    Hi there,
    Thanks for the reply from your side, I went through the document shared related to the IP FPGA Multiply Adder, In this after product operation am able to add or subtract, Moreover am not able to find a way to implement my function, So kindly let me know how to implement the function (D-A)*B.
    If possible please share me the tutorial along with it
    V. Mathiazhagan
    • YEan's avatar
      YEan
      Hi V. Mathiazhagan,
      Has this issue been resolved?
      Ean
    Mathiazhagan
    Dear YEan,
    No, Even though i went through the document u have shared am not able to find a solution, Still am working on it if i got done with it definitely i will let u know, Meanwhile if u have other tutorial related to it please share.
    Thanks in Advance
    • YEan's avatar
      YEan
      Hi V. Mathiazhagan,
      This was an older version of user guide but it expressed each mode with equation https://manualzz.com/doc/4172591/integer-arithmetic-ip-cores-user-guide . You may look at pg 57, your function can implement by pre-adder input mode. After you had customize the IP, you may just have to add a Verilog or VHDL file to declare your input and output.
      Ean
