Mathiazhagan
4 years agoMultiply and Accumulate Intel IP Core
Hi All,
Am using cyclone V E Version development board, am developing a project with the help of intel IP Cores, I could not find a IP for multiply and accumulate, after searching in google ...
Mathiazhagan
4 years agoDear YEan,
No, Even though i went through the document u have shared am not able to find a solution, Still am working on it if i got done with it definitely i will let u know, Meanwhile if u have other tutorial related to it please share.
Thanks in Advance
YEan
Contributor
4 years agoHi V. Mathiazhagan,
This was an older version of user guide but it expressed each mode with equation https://manualzz.com/doc/4172591/integer-arithmetic-ip-cores-user-guide . You may look at pg 57, your function can implement by pre-adder input mode. After you had customize the IP, you may just have to add a Verilog or VHDL file to declare your input and output.
Ean
