NWein's avatar
NWein
5 years ago
Multiple questions: writing to PCIe TXS port with 64-bit addressing (Cyclone10GX)
I'm attempting to do DMA writes to the TXS port, with 64-bit addressing enabled. A SignalTap trace shows the bus transfers working fine, but data is not appearing in main memory (at least, not where...
  • SengKok_L_Intel's avatar
    5 years ago
    1. Yes, you are right. No translator is needed for 64 bit addressing.
    2. The TXS port, it is using byte addressing. If you set the address to 33, the memory size that you can access is 2^33 bytes. From the Platform designer, you will see the address range is from 0x0 to 0x1_ffff_ffff when the addressing width is 33 bits.
    Regards -SK
