host's avatar
host
1 year ago
Multi-rate Ethernet valid signal behavior
I'm working with the 1G/2.5G/5G/10G Multi-rate Ethernet PHY IP Core on an Arria V device.
https://www.intel.com/content/www/us/en/docs/programmable/683171/current/introduction-to-the-protocol-specific.html#joc1445401896251
I fixed my IP to 2.5G and have a question about the gmii16b_rx_dv signal.
The datasheet explains that this signal marks which of the 2 bytes are valid:
Is it possible for one of the bits of gmii16b_rx_dv to be '0' in the middle of a packet ?
Or it can happen ONLY in the last byte ?
  • Hello,
    Good day.
    The lower byte (gmii16b_rxd[7:0]) contains the valid data.
    Hope this answer your query.
    Pavee
  • Hello,
    It can happen only in the last word of a packet.
    In the middle of a packet, both bits of gmii16b_rx_dv should always be '1'.
    Pavee
    • host's avatar
      host
      Thanks for the input.
      When it does happen, which of the bytes will contain valid data [15:8] or [7:0] ?
  • Hello,
    Good day.
    Pavee
  • I’m glad that your question has been addressed, I now transition this thread to community support.
    If you have a new question, feel free to open a new thread to get the support from Altera experts.
    Thank you.
    Pavee
