16 years agoMulti channel TSE with GBX (Arria II GX)
In one of our future boards, we+re going to use an Arria II GX FPGA, which will have 5 Ethernet connection using either SGMII or 1000-X. I'm current ly working with an Evalboard using an SMA conne...
14 years agoHello Videoman,
I am trying to use a Multiport TSE MAC using the Altera's ST multi-channel FIFO. But any port of TSE MAC that should be connected to an external FIFO has an different associated clock. Because of that, I am not being able to connect all the ports from TSE to a Multiplexer to be latter connected on the multi-channel FIFO as suggested in the documentation. When I try to use the Altera's ST Multiplexer I get the following error messages: "Error: System.tse: tse.receive_0 and multiplexer_0.in0 must be on the same clock domain, since they're connected" "Error: System.tse: tse.receive_1 and multiplexer_0.in1 must be on the same clock domain, since they're connected" ... and so on for all the ports I try to fit So, may I ask, how did u do with the external TSE FIFOs of your multiport TSE design? Thank you
