17 years agompeg ts interface ip core
hi; i'm working in hardware imlementaion of an DVB_ASI interface project. i downloaded the latest ip from altera site and i didn't find the ip core of the mpeg ts interface (i think it's an mpeg-2...
17 years agoWell this is my IP(haven't tested the code, so look for those bugs), it will serve as input to your ASI module
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity mpeg_generator is
port(
reset : in std_logic;
clk : in std_logic;
enable : in std_logic;
data_vld : out std_logic;
data : out std_logic_vector(7 downto 0)
end entity;
architecture rtl of mpeg_generator is
signal byte_counter : integer range 0 to 255;
begin
process(reset, clk)
begin
if(reset = '1')then
byte_counter <= 0;
data_vld <= '0';
data <= x"00";
elsif(rising_edge(clk))then
if(enable = '1')then
byte_counter <= byte_counter + 1;
data_vld <= '1';
case byte_counter is
when 0 => data <= x"47";
when 1 => data <= x"1F";
when 2 => data <= x"FF";
when 3 => data <= x"10";
when 4 to 187 => data <= std_logic_vector(to_unsigned(byte_counter,8));
when others => data_vld <= '0'; data <= x"00";
end case;
end if;
end if;
end process;
end rtl;
