14 years ago
Modular sgdma messes with ueser logic writing/reading of SDRAM
Dear all,
I have a Qsys system with PCie, user logic, DDR2 SDRAM. I use user logic to continuously write/read a DDR2 SDRAM. It seems working properly. I use windriver to write/read from DDR2 SDRAM, it seems working properly too.
Now I want to add sgdma to do fast communication between PC and DDR2 SDRAM. After I add sgdma, and connect its to DDR2 SDRAM, the continuously writing/reading seems stop even I don't issue a DMA command yet.
Why the modular sgdma stops/interferes my reading/writing to DDR2 SDRAM using user logic? anyone can give me some advices?
Thank you very much!
    Thanks, how to know if the SGDMA is configured correctly?
    --- Quote Start ---
    Probably because SGDMA is not configured correctly.
    --- Quote End ---
    Interesting question... If it's not working, then maybe it is not configured correctly, isn't it?
    Read the documentation and check all the required parameters. Also take design examples into consideration.
