Model sim error - fPLL
- 5 years ago
Since you are using Quartus Prime Pro edition, you will need to edit your .do file before you simulate your project. From your .do file you are missing a lot of commands:
- Compile all design and testbench files in your project. "vlog -vlog01compat -work work ../<design and testbench files>"
- This is to set the top-level simulation or testbench module/entity name. "set TOP_LEVEL_NAME <simulation top>"
- Call command to elaborate your design and testbench. "elab"
- To run the simulation. "run -a"
You can refer to section 1.4 of this document to understand better: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-20093.pdf#page=6
You also need to save your file as wojtek.do instead of wojtek.tcl.
Nurina
Nurina
Since your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
