Model sim error - fPLL
- 5 years ago
Since you are using Quartus Prime Pro edition, you will need to edit your .do file before you simulate your project. From your .do file you are missing a lot of commands:
- Compile all design and testbench files in your project. "vlog -vlog01compat -work work ../<design and testbench files>"
- This is to set the top-level simulation or testbench module/entity name. "set TOP_LEVEL_NAME <simulation top>"
- Call command to elaborate your design and testbench. "elab"
- To run the simulation. "run -a"
You can refer to section 1.4 of this document to understand better: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-20093.pdf#page=6
You also need to save your file as wojtek.do instead of wojtek.tcl.
Nurina
Is the fPLL written by you or did you instantiate it on Quartus?
Do you have a testbench? Can you show us the code for your testbench?
Can you also share your .do file?
Nurina
- Wojtek_Poland5 years ago
Hi!
I created separated project in order to investigation problem. Previously problem occurs in project which was including all neccessery PHY components - Transceiver PHY, Reset and PLL (fPLL). correctly connected. So i uploading separated project (Nowyfolder5) where only is fPLL component.
Tesbench: fpll_symulacja_test_o
Do file: wojtek.tcl in Nowyfolder5\fpll_o\pllka_o\sim\mentor
