fa_fpga_enthusiast
1 year agoMissing *.qprs File Support for EMIF IP in Quartus 24.3.1
Hello, In Quartus 24.1, all External Memory Interface (EMIF) IP cores included an option to provide a memory configuration file (*.qprs file) as input to the IP core. However, in Quartus 24.3.1, thi...
AdzimZM_Altera
1 year agoHello,
The support for the Memory Device Description IP has been discontinue starting with Quartus version 24.3.
The EMIF IP GUI has changed to improve the user experience.
If you want to create a preset for the EMIF IP, you can do it in the Presets window.
The Presets should be available in the Platform Designer.
After you have finished configurating the EMIF IP, you can save that EMIF setting in the Presets.
You need to click on "New..." button, give the name for the preset and save it.
If you want to use the preset, you need to make sure that the qprs file is available at the quartus project directory.
Adzim
