MCDMA/PCIe - what is frequency of coreclkout_hip?
- 3 years ago
I think that indicates the Clock Fmax.
If you changed the optimization Mode from Balanced to Aggressive Area you can achieve the 500MHz.The Fmax specification is based on the fast clock used for serial data.
The interface Fmax is also dependent on the parallel clock domain which is design dependent and requires timing analysis.
Hope this clarified.Regards,
Wincent_Intel
Apologize for late reply, as I am looking at the design provided by you.
I am able to replicate your issue based on the MCDMA design provided in the IP catalog of H-tile.
I am getting the same result as yours which is 500MHz.
The next action I will do is to raise an internal ticket to the responsible team.
Temporarily we do not have any solution to this issue, expected to be fixed in next release version of Quartus.
I will update you if there is any update from the related team.
Wincent_Intel
Hi Wincent,
Thanks for the confirmation and your support.
I think you can close the case now.
TN
