Ashoo
5 months agoMCDMA IP D2H Queue Reset Failure during Channel Re-allocation
After successfully loading the binary and launching D2H (Device-to-Host) operations on my FPGA, the first channel is allocated successfully and transfers data without issue. However, when I try to al...
Wincent_Altera
5 months agoHi,
First and foremost, which design and targeted you are verifying for this issue ?
Is this a custom design ? or the design from our design example ?
- IF this is custom design , I do suggest you to try our our design example as it is well validated.
- IF you already using the example design, can you please provide me any of you failing log ? for example the dmseg log.
Wincent_Altera
