SLabe
5 years agoMCDMA example design Modelsim Simulation failing for Agilex
Hi, when following the steps in UG for MCDMA example design in Quartus PE 21.1, I get the following error in Modelsim.
# ** Error: (vsim-3033) Instantiation of 'ctp_tile_encrypted' failed. The desi...
RichardT_altera
5 years agoMay I know which MCDMA example design that you are referring to ? Which UG?
Kindly help to clarify on this so that we are aligned.
The error is saying that ModelSim can't find this design unit. There could be something wrong with the instantiation of the "ctp_tile_encrypted" module in ctp_hssi_atoms.sv file. You may need to check on this.
SLabe
5 years ago@RichardTanSY_Altera , were you able to reproduce my error? I did see online that simulation for MCDMA P-Tile PCIe may only be supported by Modelsim SE, PE and Questa from Mentor. Could this be the issue? If so, will the new Questa Intel FPGA Edition Beta work? (I'm waiting on a license to try)
Thank you!
