TimHagen
6 years agoMAX10 TSE reference design
This is the MAX10 reference design - this was modified from what is posted on the design store that does not run:
The TEST_MAC_LB 1000M and TEST_MAC_PHY_LB 1000M tests run successfully. 1G and 10/...
Johny123
3 years agoHey Tim, thanks for the update here. Is there also a working reference designs for the max10 webserver (remote update) with tse-mac available in the store. The existing reference designs do not pass the qsys build from 17.0 onwards.
- drbarryh9 months ago
Contributor
Hi Johny,
Yes that;s what i discovered too. The 2017 one was upgradeable to Quartus 2018, then it builds and appears to pass timing, but al the TCL commands failed....such as TEST_MAC_PHY_LB 1000M, TEST_MAC_LB 1000M. I need to use the TSE in Gigabit mode. It seems like Tim says the failures are due to bad timing.
cheers, Dr Barry H
