max10, fiftyfivenm_crcblock, crc error do re config internally?
Although the original question is about 2 years old, I think this solution can be of interrest to others as well.
Most of this is based on the Max10 Handbook page 3-9 "Accessing Error Detection Block Through User Interface" and some guessing and trying of the actual vhdl component interface.
Through try and error, I determined it also needed an lcell (or non-trivial logic) in order to route the crc output signal to arbitrary pins. Without it, it was limited to the special-use crc_error pin.
The uses of the internal output signal of the crcblock does not require one to activate the external crc_error pin in the device settings.
I only tried this in Quartus 18.1, not in hardware yet:
library ieee;
use ieee.numeric_std.all;
use ieee.std_logic_1164.all;
library lpm;
use lpm.all;
entity XYZ is
port(
ErrorOut : out std_logic
end entity;
architecture arch of XYZ is
component fiftyfivenm_crcblock is
generic (
oscillator_divider : integer range 2 to 256 := 1 -- default is nonsense
port (
clk : in std_logic := '0';
shiftnld : in std_logic := '0';
ldsrc : in std_logic :='0';
crcerror : out std_logic;
regout : out std_logic
end component;
component lcell is
port (
a_in : in std_logic;
a_out : out std_logic);
end component;
signal CRC : std_logic;
signal CRC_lcell : std_logic;
begin
X1: fiftyfivenm_crcblock
generic map( oscillator_divider => 256 )
port map( crcerror => CRC );
L1: lcell port map( a_in => CRC, a_out => CRC_lcell );
ErrorOut <= '0' when CRC_lcell='1' else 'Z'; -- Open drain output with proper polarity for nConfig
end architecture;(The code is taken from a larger code block for one of my projects.)
Some other remarks about the crc error block:
- It looks like the crcblock was part of the old megawizard plugin, but it has no equivalent in the new IP catalog.
- Based on the documentation I conclude that a crc error does not automatically induce a reload of the configuration. I also noted that the polarity of the crc_error pin and the nConfig pin is opposite - direct connection will not work.
