14 years agoMATLAB/DSP Builder megablock timing issues
I am trying to use the fir_compiler_v11 Megablock in MATLAB/Simulink but can't figure out how to change the internal timing. I have 200 coefficients that I want to use only one multiplier with. I hav...
14 years agoI did mean Simulink sample time. However when I open the Megablock GUI there is no way to modify the clock time of the block. I can change the amount of clocks to compute which changes the multipliers used accordingly. When I set the clocks to compute to compute to 200 (because I have 200 coefficients) and run the simulation in MATLAB the output changes every 200 seconds of simulation time. This tells me that the Megablock sample time is 1 second which doesn't make any sense.
