14 years agoMatLab DSP-Builder Java Error
Hi, after installing Quartus 11.1 then SP2 I install DSP_Builder 11.1SP2. Then I added dspb which was included successfully. During adding dsp_builder, with the setup dsp_builder.m an error...
14 years agoHi,
I think the install of the DSP Builder 11.1 SP2 has bug. The Matlab directories are not recognized by Quartus so you have to manually point to the relevant Matlab, (R2011 should be ok for the 11.1 SP2). On my PCs, Matlab are installed in their default directories ("Programs Files"), perhaps there is a new (old) issue with the space character in the "Programs Files". There is something approaching about your problem in the KDB : http://www.altera.com/support/kdb/solutions/spr346843.html I'm quite disappointed by Q11.1 SP2 in general because I encountered too much issues (Blaster not recognized by Q11, bad devices install on one PC, DSP Builder bad install with new bull**** FSM editor, bad prefit of Stratix V etc...). Hope all of this will be resolved in Q12.
