Patriet
5 years agoMapping of IP core to product codes
HEllo, we are getting OpenCore Plus on some of the IP in a design. How do I know from the product code which IP it is actually looking for?
Also, I am getting the same message on FIR Compiler......
AR_A_Intel
5 years agoHi
Thanks for your update. I’m not familiar with FIR compiler IP. For your information, I’m just supporting dev kit general usage enquiry and licensing issue. If you are looking for further consultation on FIR compiler usage, the recommendation is for you to file new case requesting FIR compiler support.
For unlicensed items, you could check at assembler report.asm.rpt file
• The assembler report is located in <Project directory>/Output_files/<project_name>.asm.rpt.
