Patriet
5 years agoMapping of IP core to product codes
HEllo, we are getting OpenCore Plus on some of the IP in a design. How do I know from the product code which IP it is actually looking for?
Also, I am getting the same message on FIR Compiler......
Patriet
5 years agoThanks for the quick reply. I saw that FIR Compiler was obsoleted but this is a very old design. Shouldn't my FIR Compiler II license provided by IP Base work for the old FIR Compiler? It does not seem to be using it because it says unlicensed.
Also, where can I find a mapping of authcodes to actual IP name? This issue comes up a lot and it seems there should be an easy way to map these authcodes to the actual IP core?
Thanks!
