15 years ago
MAC Address on altera de2 board
Helo,
i am using the altera de2 board and sending a packet via DM9000A ethernet controler .
i need the MAC address of the board , how knows in Which sector can i find it in the Flash memory.
thanks
    Hope this can help you (it is a portion of the attached zip file):
    * get_board_mac_addr
    * Read the MAC address in a board specific way
    error_t get_board_mac_addr(unsigned char mac_addr)
      error_t error = 0;
      alt_u32 signature;
      alt_u32 mac_addr_ptr = EXT_FLASH_BASE + ETHERNET_OPTION_BITS;
    /* This last_flash_sector region of flash is examined to see if
     * valid network settings are present, indicated by a signature of 0x00005afe at
     * the first address of the last flash sector.  This hex value is chosen as the
     * signature since it looks like the english word "SAFE", meaning that it is
     * safe to use these network address values.
      /* Get the flash sector with the MAC address. */
      signature = IORD_32DIRECT(mac_addr_ptr, 0);
      if (signature != 0x00005afe)
        error = generate_and_store_mac_addr();
      if (!error)
        mac_addr = IORD_8DIRECT(mac_addr_ptr, 4);
        mac_addr = IORD_8DIRECT(mac_addr_ptr, 5);
        mac_addr = IORD_8DIRECT(mac_addr_ptr, 6);
        mac_addr = IORD_8DIRECT(mac_addr_ptr, 7);
        mac_addr = IORD_8DIRECT(mac_addr_ptr, 8);
        mac_addr = IORD_8DIRECT(mac_addr_ptr, 9);
        printf("Your Ethernet MAC address is %02x:%02x:%02x:%02x:%02x:%02x\n",
                mac_addr,
                mac_addr,
                mac_addr,
                mac_addr,
                mac_addr,
                mac_addr);
      return error;
    Thenks for your help,
    i have another Question, so the address of the MAC is the first address of the last flash sector in the de2 board ( 0x00005AFE).
    so How can i know in this way the IP?
    tnx
    I think the first address of the last flash sector is only a signature, the MAC address is found where mac_addr_ptr is pointing.
    The IP address is defined in simple_socket_server.h
     * The IP, gateway, and subnet mask address below are used as a last resort
     * if no network settings can be found, and DHCP (if enabled) fails. You can
     * edit these as a quick-and-dirty way of changing network settings if desired.
     * Default IP addresses are set to all zeros so that DHCP server packets will
     * penetrate secure routers.  If DHCP will not be used, select valid static
     * IP addresses here, for example:
     *           IP: 192.168.1.234
     *      Gateway: 192.168.1.1
     *  Subnet Mask: 255.255.255.0
     */# define IPADDR0   192# define IPADDR1   168# define IPADDR2   1# define IPADDR3   234
