DWolf
7 years agoM9K BRAM on Max 10: Data at wrong addresses?
I'm using an M9K BRAM in single clock, dual port mode. It is controlled by two state machines, one writing data, and one reading data. I'm looking at all of the signals in signal tap, and everythin...
AndyN
7 years agoCan you share the code for your write state machine? The most likely situation is that the address and data are out of step with each other...
