vic
1 month agoLTPI IP - any plan to support OCP LTPI Revision 1.2? (MAX 10)
Hi, We are planning to purchase the Altera LTPI IP, targeting MAX 10 (Quartus Prime Standard Edition). The LTPI IP User Guide states the IP is compliant with OCP DC-SCM 2.1 LTPI revision 1.1, versi...
Farabi_Altera
1 month agoDo you have further question?
- vic1 month ago
This is the LTPI 1.2 specification and reference implementation information I found for your reference:https://github.com/opencomputeproject/HWMgmt-Module-DCSCM-LTPI
- Farabi_Altera1 month ago
Based on the referenced materials, there is no publicly documented plan or timeline confirming that the Altera LTPI IP will be updated to OCP DC-SCM LTPI Revision 1.2.
The Altera documentation currently identifies the IP as compliant with LTPI Revision 1.1. The OCP reference implementation lists release 1.20, dated 12 December 2025, as compliant with LTPI Revision 1.2.
Hi Vic, do you have further question?
