Mikexx
3 years agoLPDDR2 IP woes
I am using the Quartus Lite application from 17.1 to 22.1, all varieties have been tested.
In essence I am porting a design that was tested on a:
Terasic Technologies Cyclone V GX Starter Kit ...
AdzimZM_Altera
3 years agoHi Mike,
Are you using an example design generated from Quartus software?
Can you provide some snapshots of the EMIF IP setting as well?
Adzim
Mikexx
3 years agoMany thanks for your reply.
This is a bespoke design using a Terasic design involving the HDMI interface. This is based on the 5CGXFC5C6F27C7N. The design has been ported with minimal changes apart from pins in the ".qsf" file.
I hope the following helps. They are the same settings for both target devices.
