Low Latency 100G Ethernet bring-up : read 0xdeadc0de
- 5 years ago
HI,
One of the possibility is you are reading the reg from invalid/incorrect memory region.
You may want to check the reg address memory mapping in your design again.
dlim
Hi Dlim,
actually I noticed that I had forgotten to enable RS-FEC in the IP, since I enabled it, my design is not able to pass fitter.
Fitter reports "cannot place node [...] for hundreds of lines.
My design is very simple and almost empty (only 10% of FPGA logic is used), it contains :
4 times :
[100G ethernet IPs] + logic to answer to an ARP or ICMP request (ton answer PING).
I am guessing the design is not constrained enough, I have generated the low latency 100g ethernet FPGA ip example design, and I got inspired by the .sdc constrain file provided in it. Basically :
for { set i 0 } { $i < $x100g_count } { incr i } {
set THIS_RX_RS_CORE_CLK [get_clocks gen_XG[$i].xg_wrapper|GEN_100G.av_top|alt_e100s10_0|WITH_FEC.fecpll|RXIOPLL_INST.fecrxpll|alt_e100s10ex_iopll_rx_outclk0]
set THIS_RX_RS_CORE_NCK [get_clocks gen_XG[$i].xg_wrapper|GEN_100G.av_top|alt_e100s10_0|WITH_FEC.fecpll|RXIOPLL_INST.fecrxpll|alt_e100s10ex_iopll_rx_n_cnt_clk]
set THIS_TX_RS_CORE_CLK [get_clocks gen_XG[$i].xg_wrapper|GEN_100G.av_top|alt_e100s10_0|WITH_FEC.fecpll|TXPLL_IN.TXFPLL_INST.tx_pll_gen.fectxpll|clkdiv_output_div1]
set THIS_RX_CORECLK [get_clocks gen_XG[$i].xg_wrapper|GEN_100G.av_top|alt_e100s10_0|xcvr|rx_clkout2|ch1]
set THIS_TX_CORECLK [get_clocks gen_XG[$i].xg_wrapper|GEN_100G.av_top|alt_e100s10_0|xcvr|tx_clkout2|ch1]
set THIS_REF_CLK [get_clocks cg_ref[$i]]
set_clock_groups -exclusive -group $THIS_TX_CORECLK -group $THIS_RX_CORECLK -group $THIS_TX_RS_CORE_CLK -group $THIS_RX_RS_CORE_CLK -group $THIS_RX_RS_CORE_NCK -group $TRS_DIVIDED_OSC_CLK -group $STATUS_CLK -group $REF_CLK
# set false path from PMA fifo flags' clock to clk_status (ex_100g_inst|ex_100g_inst|alt_s100|csr|eio_flags_csr[*])
for {set chNum 0} {$chNum < 4} {incr chNum} {
set RX_CLK [get_clocks gen_XG[$i].xg_wrapper|GEN_100G.av_top|alt_e100s10_0|xcvr|rx_pcs_x2_clk|ch$chNum]
set TX_CLK [get_clocks gen_XG[$i].xg_wrapper|GEN_100G.av_top|alt_e100s10_0|xcvr|tx_pcs_x2_clk|ch$chNum]
set_clock_groups -exclusive -group $RX_CLK -group $STATUS_CLK -group $TRS_DIVIDED_OSC_CLK
set_clock_groups -exclusive -group $TX_CLK -group $STATUS_CLK -group $TRS_DIVIDED_OSC_CLK
Do you see any constraint missing here?
