local_reset_done and emif_usr_reset_n on emif ip
Could someone please help me understand difference and relation between these two signals on the emif ip - local_reset_done and emif_usr_reset_n ?
If I toggle local_reset_req to the ip, then local_reset_done will go low indicating that the ip is in reset. at some point it will go high indicating that it is out of reset.
what happens to emif_usr_reset_n after i toggle local_reset_req ?
which one of the two signals will go high first?
I have a design where emif_usr_reset_n is high but local_reset_done is still low.
Assuming that a high on emif_usr_reset_n means that the ip is out of reset, should not local_reset_done be high before or at least at same time that emif_usr_reset_n is high?
I looked at the user guide but it does not have much in terms of details.
- AdzimZM_Altera
local_reset_req (input)
local_reset_done (output)
local_reset_req has effect only when local_reset_done is high.
The local_reset_done signal transitions high once the calibration is completed.
Once the reset is requested (local_reset_req = high, for at least 2 EMIF core clock cycles), the EMIF interface will enter reset sequence (local_reset_done = low).
Then the core reset signal (emif_usr_reset_n) is driven low. The emif_usr_reset_n is active low signal.
After the reset sequence is done, local_reset_done is driven high again.
Adzim
- CosmoKramer
Thank you for replying. But my question was which one of the two - emif_usr_reset_n, local_reset_done - goes high first?
or do they go high at same time?
- AdzimZM_Altera
emif_usr_reset_n is an active low signal.
It's asserting when entering reset sequence then perform calibration.
local_reset_done is a active high signal.
It's asserting when the calibration is done.
According to the initialization flow, the memory will run a calibration first before it's able to accept command from user logic.
Therefore, the emif_usr_reset_n should be trigger first.
Adzim
- CosmoKramer
Just to make sure i understand it correctly, please confirm:
1) after user issues reset_request, which of the two signals go high first:
emif_usr_reset_n
local_reset_done
2) When these signals go low to high, it means that IP is out of reset. is that right?
thank you.
- AdzimZM_Altera
"1) after user issues reset_request, which of the two signals go high first:
emif_usr_reset_n
local_reset_done "
- The local_reset_done should go from high to low. (active high)
- Then emif_usr_reset_n should go from high to low. (active low)
- The emif_usr_reset_n will go high again based on the calibration sequence.
- Then after the calibration is finished, the local_reset_done will go high again.
"2) When these signals go low to high, it means that IP is out of reset. is that right?"
- Yes.
Adzim
