vitor_woyakewicz
4 years agoLinuxPTP using intel TSE MAC IP
This is my first time on the Intel Community Forum, so I apologize if i dont follow some community guidelines.
I am trying to make an implementation for PTP time synchronization using a DP83640 PH...
paveetirrasrie_Altera
4 years agoHello Vitor,
Good day.
You could also check TSE MAC configuration through example design in AN647. I have attached the link for your reference. Try to compare the MAC configuration with your design.
Kindly download the example design and unarchive, there is a file called "config.tcl", this file contains the TSE MAC register setting. System console will source this file to configure the TSE MAC register.
Pavee
