11 years agoLegacy interrupt issue in pcie hard_ip
hi, we are using altera Pcie hard ip (stratix-4GX). We have generated an interrupt using legacy i.e in hard ip we have controlled an interrupt using app_int_req,app_int_ack variables In hard ...
11 years agoPCIe core configuration space register address 0x3D defined Interrupt Pin as below:
- 0x00: No INT x# pin used - 0x01: INTA# used - 0x02: INTB# used - 0x03: INTC# used - 0x04: INTD# used The Interrupt Pin is default to 0x01: INTA# used. When have multiple legacy interrupts, this field might needs to change to avoid conflict.
