Jesd204B compile failed
Hi David
The twentynm_pma.zip that you attached only contains 1 file (twentynm_pma.sv), unable to compile.
Please attach the Quartus project archive (.qar) so that I can compile to duplicate the error.
In between, 'JESD204B Intel FPGA IP Core – Support Center' at below link include some Arria 10 JESD204B reference designs, worth to take a look and you might download these reference designs and modify according to your need. Thus, could avoid the compilation error due to wrong pin assignments.
- dsun014 years ago
Contributor
Hi Skbeh,
Thank you very much for help.
The whole design used 4 4-lane cores; I made a mistake will I assign the pins. now I can compile without problem.
in the meantime, I do have a very critical application question which I opened a new thread here.
Fundamental question about Jesd204B, Lanes VS ADCs - Intel Communities
if you have time, please give me some suggestions.
Appreciate your help.
David
