JESD204B (Agilex F-Tile) v1.0.0 - Support Logic Generation Error (Quartus 22.1)
- 4 years ago
Hi Toby,
Good day.
Thank you for your patience.
>Is this an issue with the 22.1 release?
At the moment, there is no known issue such as the error(21842).
We have tried with Intel® Quartus® Prime Software version 22.1 from our side but did not manage to replicate the error.
We suggest you to try generate our design example as per the JESD204B Intel® Agilex™ FPGA IP Design Example User Guide to see if this error still happen.
If the error still occur, please do attach your design here for us to have a look.
Thank you.
ZulsyafiqH_Intel
Hi Toby,
Good Day.
Apologize for the delayed response.
Due to some the technical error, we have just receive your reply.
>Do you know if there is a separate document to cover this?
I'm afraid that we only have1 User Guide for Agilex at the moment.
>Is it possible to clear the accepted solution on this post as it has not been resolved?
I have tried to remove it but I cannot due to system limitation.
After further discussion with internal team, it is found that I can only change the accepted solution but not remove it. Hence, once we have come to the final solution, I will change it.
May I know your Agilex F-Tile device type? The product variant?
So that I can create a sample Example Design from my side for you to test on your side.
Thank you.
ZulsyafiqH_Intel
