CHebl
7 years agoJESD204 IP-Core occasionally receives wrong data in internal loopback mode
I'm currently trying to implement the JESD204-IP Core to receive data from an ADC on an Arria 10 using Quartus Prime v18.1. To test the receiver I implemented both channels (TX and RX) of the Transce...
Nathan_R_Intel
Contributor
6 years agoHie Chris,
I tend to agree with you, your observation could be caused by something in the receive path. However, the data integrity should be good as long as no 8B10B error (as I mentioned previously).
Can you attach your simplified design achieve (.qar) containing the JESD IP configuration with a connection to a black box (without your design) so , I could understand your design configuration to advice further whats going wrong.
Nathan
