David32
3 years agoJESD Test Bench Simulation - no activity
Hello I am using Quartus Prime Pro 22.4.0 on Windows and Questa Intel Starter FPGA-64 2022.1 on Windows. The full path to my project is: c:/jesd and the project name is also "jesd". The JESD204B...
ZH_Intel
3 years agoHi David,
Thank you for your patience and reply.
We have run some tests from our end, at the moment, we did not find any abnormality and is working fine.
Screenshot
Screenshot 2
If you follow the steps above, by right it should be working fine.
Q1. May I know the exact steps that you use to run the simulation? (command used), and Is there any licensing issue when opening Questa Intel Starter?
Q2. Could you try it on linux environment?
Q3. Are you running multiple Quartus version in your operating system? Could you please check you environment variables if the directory is correct.
Environment Variables window
I would also like to suggest below item and see if symptom still happens from your end:
- re-generate your design in a new folder and re-run the simulation.
- use the latest Quartus version for your design.
Thank you.
ZulsyafiqH_Intel
