JBC player download
- 3 years ago
Intel has a habit of making old stuff disappear, where Altera just let it hang around.
It appears if you harangue Intel hard enough and get an NDA signed they may give you the old code.
Or just look here: https://github.com/margro/jam-stapl
Hi JSis,
I wish to follow up with you about this case. Do you have any further questions on this matter?
Please feel free to let me know if there is any concern so that we could further assist you.
Otherwise, this thread will be marked as inactive and will be transitioned to community support because there is no update received from you in a while.
Fakhrul
Your link works, but I only see .exe files, no source files. So margo/jam-player is still the only possible solution. The original idea was to use the JAM byte-code player source codes (works with .jbc file) to implement into the microcontroller, but jam-player (works with .jam file) seems to be the only possible way... Thanks.
