AKhel1
6 years agoIssues using ST-Avalon on Stratix 10 MX development Kit
Hello, I am porting an endpoint PCIe IP on my Stratix 10 MX development kit (1SM21BHU2F53E1VG) and I have some issues. When using a test IP (xillybus) with ST-Avalon PCIE gen2 x8 and a correct pin...
BoonT_Intel
6 years agoNoted.
What problem with the reset? I will suggest just follow the Quartus auto fit. Eg, compile the example design without location assignment and see it assign the rest to which pin. If you need further help, I hope you can create a new thread for this. It can help every single issue is track under independent thread. Ease the other to search if they are facing same issue.
