AKhel1
6 years agoIssues using ST-Avalon on Stratix 10 MX development Kit
Hello, I am porting an endpoint PCIe IP on my Stratix 10 MX development kit (1SM21BHU2F53E1VG) and I have some issues. When using a test IP (xillybus) with ST-Avalon PCIE gen2 x8 and a correct pin...
BoonT_Intel
6 years agoHello, can you just follow the error message instruction to assign the pin accordingly? eg. Assign the specified data signal < pcie_tx[0] > to pin < PIN_BL47 >.
You need to follow the error message instruction to assign all 16 pins accordingly.
Anyway, from the attached design, I found it already compiled successful. Is there some misunderstanding here? I guess the design is working previously. but after you changed something and you get the fitter error? if yes, please clarify what change that you did. 😃
