Issue of PS/2 IP core
I have implement a porgram which show the key from keyboard on VGA, but now i meet a trouble. it show twice character whenever i press the keyboard. I try to set a breakpoint at the condition if (decode_mode == KB_ASCII_MAKE_CODE );, then everything work properly. But when I remove the break point it show the character twice.
Can any one advice this? Thank you#include "system.h"# include "stdio.h"# include "altera_up_avalon_character_buffer.h"# include "altera_up_avalon_pixel_buffer.h"# include "altera_up_avalon_ps2.h"# include "altera_up_ps2_keyboard.h"
/*Function that read keyboard input and show on monitor*/
void read_keyboard(alt_up_ps2_dev *ps2_kb, alt_up_char_buffer_dev *vga)
KB_CODE_TYPE decode_mode;
alt_u8 buffer;
int x = 0, y = 1; //If y start from 0 character will hide on the top of monitor
char ascii;
char *inputStr;
alt_up_char_buffer_init(vga);
alt_up_char_buffer_clear(vga); //Clear previous character on the screen
while(1)
if (decode_scancode(ps2_kb, &decode_mode, &buffer, &ascii)==0) //If get a make code from keyboard
translate_make_code(decode_mode, buffer, inputStr); //translate the code like "SPCAE", "BACKSPACE"
alt_up_char_buffer_string(vga, inputStr, x,y);
x++;
if (x > 80)
y++;
x = 0;
if (y > 60)
y = x = 0;
int main(void)
alt_up_ps2_dev *ps2 = alt_up_ps2_open_dev("/dev/up_avalon_ps2_0"); //open PS/2 device
alt_up_ps2_init(ps2);
alt_up_ps2_clear_fifo(ps2);
alt_up_char_buffer_dev *vga = alt_up_char_buffer_open_dev("/dev/up_avalon_character_buffer_0");//open vga device
if (ps2->device_type == PS2_KEYBOARD) //Check if the device connected to PS/2 is keyboard
read_keyboard(ps2, vga);
else
printf("Error...\n");
return -1;
have you solve the problem?
I am having this same problem. I'm also calling decode_scancode() in a while(1) loop, and it always gives me to make codes (press and release), never any break codes.
Anyone else have this issue? My code is essentially the same as ctkhai's Regards, Jonathon - Altera_Forum
Hi all, where did you get altera_up_avalon_character_buffer.h?
I am not finding this file in my PC at all. - Altera_Forum
@waiyung, Do you have the University Program IP packages installed? Anything with "_up" in it is referring to University Program.
By the way, all, this is definitely some sort of timing issue. I too got it to work while debugging and stepping through the program, but not running at full 16MHz. I wondering if its managing to pull the same code from the buffer twice before it is cleared or something. I know it's not elegant, but inserting some sleep (somewhere, I can't remember now) did the trick.
Yes, I have UP package installed. But it does not have the header file altera_up_avalon_character_buffer.h
I double checked it by searching through my PC. This file is not there. But I found altera_up_avalon_video_character_buffer_with_dma.h Also, in the system file, I cannot find the character_buffer either. Any idea?
