Eyal_G_Intel
7 years agoIs the matlab model for the FFT support the block float point mode? I did not see it the matlab file
1 Reply
- CheepinC_altera
As I understand it, you have some inquiries related to the matlab model for FFT. Just would like to check with you on the following:
1. Which device and Quartus version are you using?
2. Where is the specific location of the matlab file that you are looking at?
3. Probably you can share you FFT IP file so that I can have better understanding on your configuration.
By the way, based on my previous experience, generally we will configure the FFT IP, then click on Generate Example Design button and we will find the right model under *_example_design/Matlab_model. Not sure if you are using this method to generate the Matlab model.
Chee Pin
