Is the CKE port for the INCLOCK or the OUTCLOCK?
But there are 2 clock ports: clkin and clkout. In order for me not to violate setup and hold requirements, should the clken port be driven synchronously by the clkin or clkout clock?
For the GPIO input registers, the input I/O transfer will likely fail the hold time if you do not set the input delay chain.
For more info please read the Timing Closure Guidelines:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altera_gpio.pdf#page=21
- SZack6 years ago
This last reply did not really address the question which is "should the clken port be driven synchronously by the clkin or clkout clock?". Can you please answer that question?
Steve Zack (the FAE supporting this customer)
- EBERLAZARE_I_Intel6 years ago
The direction to the CKE is an INPUT.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altera_gpio.pdf#page=10
This CKE will be controlling the CLK(clkin) of the IP.
If you are using BiDir(Bi Directional data), then you will have CK_IN(clkin) and CK_OUT(clkout), which the CKE will be controlling both of clocked in and out.
Do you have any additional questions?
The CKE is basically acts as a switch, controlling the CLK of the IP.
