13 years agoIntermittent PCIE LTSSM stuck at Detect Quiet
Hi I had an intermittent issue during power-up or reset. Sometimes it works and the ltssm state is at L0. sometimes it is not working and the ltssm state is stuck at Detect.quiet. Anyone e...
11 years agoHi all, in my case LTSSM signal is stuck at POLLING.COMPLINCE mode and not going to POLLING.CONFIG mode.
To check the problem i am using signal tap 2. when i am monitoring some signals like clocks: fixedclk, pld_clk, clb_clk, like all clocks are coming and pll_locked,rx_freq_locked are coming. resets : pcie_rstn, npor,rx_digitalreset,app_rstn all reset signals are coming and reset status signal is also zero. But and when i monitored test out signal nothing is coming. so, please suggest me what to do in my case, i am not finding where the exact problem is? is there any chances to go wrong in ip core or the problem is in my custom board?
