Adithiya_R
1 year agoIntel P-tile Avalon ST BAR0 addr_offset
Hi Everyone, I am using Ptile-pcie ip in endpoint mode, Gen4 1x8 256 bit configuration and Quartus 23.4 I have an issue regarding bar0_write with a different offset. I tried the following tlp [Da...
- 1 year ago
Hi Adithiya_R,
Thanks for sharing your observation.
This is an expected behavior. The TLP header and data are dword aligned. There is no workaround to change the address alignment that I am aware of.
If you use the BAM and BAS modes on P-Tile, the AVMM address is aligned to the natural width of the data. For example, if the data width is 64B, the addresses must align to 64B.
Ven
VenT_Altera
1 year agoHi Adithiya_R,
Thanks for reaching out.
Allow me some time to investigate your issue. I shall come back to you with the findings.
Ven
